chevy 355 low compression question?
12K views 27 replies 8 participants last post by  thinwhiteduke
OK guys I am new here and looking for help. I have a Chevy 355 that is in my dirt track car. We were having problems with it blowing blue flames out exhaust and popping on deceleration. We thought it was header leak and lean mixture. We tried everything even timing. Well long story short we found the problem in the distributor the mechanical advance lockout was allowing the distributor to retard to about 17 degrees btdc when it should of been at 34. We ran two nights this way. I have now checked compression and there all at 100 except for 5 and 7 they are at 95. I didn't check the compression when I first got the engine I kick myself in the but now. But to me these numbers sound low I was thinking I should be up in the 150s+? the motor is built to be a 9:1 compression motor. Here are some of the specs Gm 3.480 crank had been sent out and counter weights cut and nitride coated gm 350 block prepped 0 deck piston height is + 002 out 4.040 bore . Scat 2 -1cr5700 rod pushrods lingth 7.950 piston -7cc
Felpro 1142 .041 thick 4.100 bore head gasket clevite ms-909p-10 main bearings rods torque 45 lbs .0047-.005 stretch mains 70 ft lbmain .0055 thrust
Rings total seal cr3690-45.
Rod bearings clevite cb-663 p-10 .23 Side clearance bullet cam Chs 278/286-064f at .50 in 248 exh 256
1.5 rocker ratio exh 532 lift in 353 cam is in at 102 heads are done with stainless swirl polish valves true 76 cc lifters are bullet with ls9925spl with oil hole
#4 ·
Bullet cam Chs 278/286-064f at .50 in 248 exh 256
I'm uncertain as to how you circle track guys build a motor, but what I hear you saying is that you have taken a camshaft that should have been screwed into a 11.00:1 to 12.50:1 static compression ratio motor according to the 248/256 @0.050" tappet lift figures you listed, but you have, instead, screwed it into a motor that has only 9.0:1 static compression ratio. Is that correct? And you're wondering why the cranking compression is low?
If you install a camshaft that is compatible with the static compression ratio, you can expect the cranking compression to be in the 150 range. If you install a camshaft that is incompatible, as you have done, then you can expect 100 cranking compression.
I figured your Dynamic Compression Ratio at 7.4:1 and I'd be surprised if you can get out of your own way on the track.
Duke was posting while I was typing, but both of us think alike.
Yes my question is does the compression sound too low?
So what you guys are saying is that I should probably be seeing low compression numbers because of the cam being to big for the motor? I was afraid I had hurt the motor running it while the timing was retarding and the engine was popping and shooting flames out the exhaust maybe rings or something because the motor does have a fair amount of blow by but it has always had some. I am no engine builder these are the specs I was given on the engine and the engine was supposedly built by a reputable race shop. And the motor when it was running right It was one of the fastest cars at the track.
#19 ·
Yes I am reading your posts.
I have checked leak down with a crappy leak down tester that only uses like 15lbs. I need to borrow a better one. The car did have some blow by through the valve cover breathers and the guage read 40%. Once again I think it was a harbor freight leak down gauge. Could the cheap gauge with low pressure contribute to a high percentage
#18 ·
It's always a crap shoot when you buy a used engine unless you know the seller real well. You might not even end up with the engine you think your buying. The first things you need to due are get a know good leak down compression tester or see what pressure yours runs. If it puts out at least 80 psi it will work. The next thing is to pull the timing cover and see if you can confirm what cam is in it. If you can't figure out what cam is in it by the numbers on the end of the cam you're going to need a degree wheel and a dial indicator set up to find out what cam you have.
Unless dictated by rules I don't see how you can run competively with flat top pistons and 76 cc heads. If you are require flat top pistons you need to run the smaller chamber heads. If you're required both flat tops and 76 cc heads you need a camshaft designed just for limited compression.
#23 ·
Ok I did another leak down test I think my gauge is messed up. I warmed the car up to 180 degrees and did the test. When I connect air ti my gauge I set the right gauge by turning the regulator until it says set which is about 15lbs on the left gauge. When I click the regulator back so it can't be turned the set gauge slowly will climb up. So I hooked it to my cylinder at tdc and it showed a leak down of 35% with a noticeable are leak from the valve covers. I realize an engine won't seal completely.
I think my % leakdown gauge (right guage) is screwed up. So I then decided to try it by using the reading only on the left psi gauge. I set the gauge to 100psi with 120 psi constant pressure to the inlet and hooked it up the psi dropped to 90 psi so I am assuming that means 10% leak down correct????
Any in site on doing the leak down this way? I'm looking for another leak down gauge to test with
#24 ·
you are guessing 10% blow by?
it takes an hour to remove most race engines or less? gaskets cost?
do you have measuring tools?The engine has a problem,it should already be apart and waiting for repair pieces,,,,
measure your cam
check deck height
fix all problems
race next week end
If you can buy parts tonight,,,
buy everything,take it apart,
replace whats needed,assemble by midnight
install and run by 3AM
race!!!
return un used parts Monday
