Difference between 87-up and pre 87 camshafts
9.9K views 11 replies 7 participants last post by  cobalt327
#4 ·
1987 and up cams
Beginning in 1987 small block V8 engines were equipped with hydraulic roller cams. There are differences in the block to accommodate a cam retention thrust plate and antirotation mechanism for the lifters. These blocks are identifiable by bolt holes for a cam retention plate behind the upper timing sprocket, as well as bosses and tapped holes in the lifter valley.
The camshafts on these engines have a step nose and smaller bolt pattern on the front of the cam. An earlier model camshaft may be used in these blocks by using the appropriate timing chain set and adding a thrust button when using a roller cam.
#8 ·
The block in my truck is was in 87-91 camaros and says its supposed to be a roller but its not.:mad: When I hold the new cam (55-85), up to the original cam that came in my truck it looks 100% identical. I cannot see a difference. Im thinking they used the older style cams back when they built these engines. Thanks for the info. So it helps to use a cam button regardless if I am using a roller cam. There was some play in my cam as in I could pull it out somewhat. Hope it will be ok, its been fine so far. Also Cobalt327 I seen you said something about bosses for dog bones. Does a roller block machined a certain way to hold the dog bones. If so Ill have to go with retro lifters on the engine build.
Thanks for the help guys. Very appreaciated:thumbup:
#9 ·
First, the cam in your engine is fine, perfectly normal and no worries there at all. Millions of SBC engines were built this way and millions have been modified for a LOT more power and they use the same type cam.
CAM BUTTON
Using a cam button on a flat tappet cam helps keep it from moving fore and aft, which causes the timing to vary a small amount and can also set up harmful harmonics in odd cases. But generally speaking, the way the lobes are ground w/a slight angle to them, along w/the way the distributor gear/cam gear interface, and the cam timing gear-to-block clearance and the timing set gear alignment all work together to keep the cam fairly well located in the block.
But if you have the time, desire, and patience to set it up w/a button and to be sure the timing set alignment isn't 'fighting' against the button, AND if the timing cover is sufficiently stiff to provide a solid point for the button to register off of, then go for it! Done correctly there's no real downside, even the cost is negligible.
BLOCKS:
Some '87-up SBC blocks were fully machined for the hydraulic roller cam. Some blocks had the bosses cast in place, but the bosses weren't drilled and tapped. And other blocks lacked the bosses altogether.
Some '87-up blocks are fully machined for a mechanical fuel pump while others have partial machining w/o a hole drilled through to the cam for the pump push rod. The link I gave you above goes into some detail on this.
FACTORY ROLLER:
The dogbones hold the lifters in alignment and keep them from turning- which would instantly destroy the cam and lifter. The spider holds pressure on the dogbones to keep them in place. The retainer/thrust plate locates the roller cam in position; a roller cam lacks the angle on the lobes that work to keep a flat tappet cam from walking too much.
There are ways to use the factory roller cam spider and dogbones on a block w/o bosses. This requires drilling into the oil galley to mount the spider and the use of 3.4L V6 lifters (there are also other engines that use this same roller lifter). There are parts that are made to replace the dog bones that might give a better result. I have never used these retainers, so I can't comment further on them except to say the use of dog bones on an unmachined lifter boss doesn't seem like such a good idea to me, so the retainers might be a better solution. Now, there are early non roller engines running around just fine that are set up w/the factory dog bones- so that's my opinion alone.
My thoughts are that unless the block was something special, I wouldn't go about it this way and would instead either find a roller block or use a retro roller cam and lifters.
Factory spider, dog bones, and cam retainer plate
#12 ·
For those looking to take the easy- if a little more expensive- way around cutting the ears off the roller cam retainer and using a generic cam button to use a factory hydraulic roller cam in a non roller block, LPE has a package that includes the spacer, cam button and button head cam gear fasteners. Cost is $30-$35.
Click on image for link to the part:
