Hi, I'm rebuilding an early C-4, green dot, 24 spline, transmission that will be going behind a 170 engine in my old 65 falcon. Last night I was rebuilding the valve body and could not find the check valve balls that the Haynes manual specifies are there. All I found was a small rubber disc (about 1/8" diameter by 1/16" thick) that is used as a check valve. I referenced the 1965 factory manual and it only shows this rubber disc and no check valve balls. Can someone confirm this is correct for the early C-4's? Thanks!
