Edelbrock Torker Intake - What's it good for?
32K views 6 replies 6 participants last post by  454C10
I am in the process of acquiring a SBC and was wondering if the Torker intake that's on it is worth anything as a performance piece. This is NOT going in a daily driver but more of a street/strip truck, with emphasis on the strip. I am undecided as to whether or not to leave it stock stroke or to build a 383 out of it. Either way it will NOT be mild or very streetable. That being said, is this intake a good match for this application? Thanks.
P.S. - Sorry for the lack of specific information but there really isn't any to give. I don't have the motor yet so I don't know what cam is in it, compression ratio, valve sizing, heads, etc. I just want to know the merits/shortcomings of the design, and what it was designed for. Thanks again.
#2 ·
The torker is definitely meant for the strip side of street/ strip. Short runners and big open plenum aren't good for bottom end. However the Torker is pretty old technology and several members here have said it isn't a top performer on the top end either. I think the new standard is the Victor series for take-no-prisoner /carnivore applications.
#3 ·
Thanks for the info Willys. This will definitely be a deep breathing motor. I'll probably look more into a Victor Jr or Performer RPM Air Gap intake for my uses, but the Torker may have to do for now. As long as its a semi decent hi po intake, it'll be fine for my project for now. Being a bolt on item, it will be simple to replace down the road.
Grain of salt
I too had the idea of using a Torker II for my 383.
That was the idea until I read an article in HOT ROD (or one of them) where the did a compare of several intakes. The clear winner has always been the performer RPM air gap.
So, you may want to hit HOTROD.com and search through the archives. If I remember right the numbers were similar except at the low RPM area. I can not remember all the details but it was a good article.
Hope that give you a place to look.
(I think I am going to use my Torker for my EFI project. Cut weld and here I go!)
#6 ·
Back in the day when the TORKER was quite popular, it also cleared the hood. The Victor may not clear the hood.
A popular thing to do to the torker was to add 3/8 to 1 inch spacers depending on hood clearance. The 1 inch woke it up fairly well mid to high.
If you ever see some old photos where the hood is lifted at the cowl, it is to clear a spacer on the intake without cutting the hood. Cheap way to get cooler air under the hood too.
In a heavy truck, I would use the RPM intake. You need the extra torque to get that thing moving. I don't know why they called that a torquer intake because it has lower torque. ?????
I run a RPM intake on my SBC and it pulls hard to valve float (7200 rpms).
I did a comparo with an old torque intake and a RPM intake and the RPM intake kicked it's butt for low and mid range torque and the high rpm power was the same.
