Guy's My engine is over heating and I've run out of tricks. I already know my radiator is too small but there's nothing I can do about that. It is a four core aluminum custom built to fill every square inch of space I have.
The engine is a stock 455 Buick. I have the timing set at 8 deg BTDC with the vacuum advance hooked to a non ported site. It was running lean but I switched carbs and I now have the perfect brown on the plugs.
I blocked all front gaps so 100% of the frontal air goes through the radiator and I have a shroud that covers all the gaps on the back, except the fan. It has a high CFM 18 inch fan and it fills the entire area. There is no room for another fan. Except maybe a pusher. I tried Redline Water Wetter and it helped but I'm still not there.
Before you say get another radiator, I think I can get this one to work because it doesn't over heat running down the road ,nor does it over heat just sitting. It is just running at 210 degrees with a 180 thermostat on a 90 degree day.
Any suggestions?
Any suggestions?
