OK, I'm going to start by saying I screwed up, I used a new gun and didn't pre-rinse with Lacquer thinner. So after masking and wiping car down with wax and grease remover by spraying it on the panel and drying with paper towels. I sprayed two coats of epoxy on the whole car. I am using Transtar 6401. I let it set about 28 hrs, scuffed it lightly (320)to try and knock some of the nibs and fisheye rings off. Then sprayed two coats of Evercoat Slick sand on the sides of the car. Some of the fisheyes came through the first coat of slick sand, but, the second coat covered them. My plan is to shoot the whole car with two coats of 2k primer. Jamb car, then final sand with 400 and lay base without sealer. The reason for not using sealer was I did not want to chance it getting into the fresh painted jambs. Would like some feedback on the best way to proceed. If I get the fisheyes covered with the 2k primer will they be a problem in the base/ clear? Can I use wax and grease remover on the epoxy, even if is still in the re-coat window? Would it be best to seal vehicle prior to base coating? This is not a show quality job, just a nice driver.
