front end set up
899 views 1 reply 2 participants last post by  home brew
got a question.
which is the better frontend setup to use on a ratrod: suside or conventional with a front crossmember?
#2 ·
One is not better than another. It all depends on the look you want. Do you want your tires out in front of the grille or even with it. The suicide front suspension with the spring perch mounted above the front crossmember will allow you to get the frame down lower in the front than one with a spring mounted under the crossmember unless you Z or pie cut the front frame rails.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
