Ok, that list doesn't give much idea of the characteristics of the engine...we need cam specs, cylinder head specs, and intake manifold type. Header dimensions would help too.
From a pure power standpoint, you won't pick up anything on a naturally aspirated engine by switching to electronic fuel injection, if that is your goal.
Basically all the injection would help with is cold start manners, low and mid range street rpm drivability, and possibly fuel mileage a small amount.
The Demons are good carbs, generally not much can be improved upon if it is working, adjusted, and tuned correctly.
If you were talking about old fashioned mechanical injection, either Flying Toilet type or ram stack injection, it might improve wide open throttle power a bit, but will be worse than the carb at any other situation that isn't wide open throttle...worse idle, awful at street cruise, terrible at fuel mileage.
