I started assembling my 350 SBC motor again this weekend after having the heads skimmed slightly. The right hand head had a slight warp which caused it to leak on #8 but I think the intake gasket also leaked (incorrectly torqued) in the same area causing water to go into the lifter valley.
In the gasket set was also a set of block-off plates for the rear water ports on the intake gasket and the gasket set has a big notice that you have to use it on an 86 or later motor. Previously I didn't use the block off plates but I now did install them.
Why is it important to use it? What purpose does it have other than (in my mind) letting the manifold run hotter?
Also how can I stop the front flat rubber gasket from being pushed out from under the manifold when I try and tighten it down?
