I have a 1993 Dodge Dakota the cloth head liner is saging was wanting to fix it back need advice tips on what to do do you use some type of glue? also it is awork truck daily driver. thanks for any help also great site.
My nephew did the drew up the ram's head,I can't draw worth a crap.I leave the art work to others.stitcher_guy said:Looks nice. Did you freehand cut the Ram's head??
stitcher_guy said:Unless the board is glued in like some Lincoln products, a professional shop should have one out, cleaned, covered and reinstalled in less than three hours or you're losing money. Dodge Rams and Dakotas are a two hour job at best. For a hobbyist or amateur, go see a professional.![]()
Actually, just be very careful in the removal and cleaning. The worst part of it is getting all the clips to remove without breaking. There are tricks that you learn after about the hundredth board. I get a fair share of information seekers wanting to do their own headliner until they find out what's involved. Their next step is to schedule a time.
For the Dakota headliner, once it's out there is no problem cleaning them. Dodge uses a fibeglass coating on their boards that makes them very resilient to wire brushes. What a lot of people think with the wire brush is that you have to run it all-out, full speed to work. Wrong. Instead, set the drill to where it just turns (you're wanting torque, not horsepower on the drill). The slow scraping of the brush takes the foam off in short order with no damage to the board. The hard boards scrape clean right off. If you go too fast with the brush, it cuts down through the fiberglass layer making "mumps" on the board.
On the GM spray in boards (the layer on layer of soft insulation type material that is sprayed in originally and hardened), don't even try to completely preserve them. Even if you are careful and easy with the foam removal, what you have left is the original glue layer put on at the factory (sort of like a peel and stick stamp backing). That also needs to come off or the new glue layer will cause it to lift. I take the edge and peel that glue layer off as well. Yes, it does take a layer off the board, but it comes out smooth and the new foam sticks like it should. Best to use 1/4" or 3/16" foam to recover if you can find it. Most suppliers are just going with 1/8" anymore which is very aggravating.
Just about any board can be repaired. I've had T-Top headliners come out in five pieces and go back repaired. Use chipboard on the backside as support and repair. They come out nice and firm and ready for installation. But, more and more there are ABS boards available for the really bad ones. Not cheap, but a good replacement.
