I have a 383 stroker, on another thread I was alerted to the fact that my heads are not the best heads for my motor. I was told that is why my hp and torque numbers are so low (for a 383). With what I have listed below is there any way to figure out what heads would be best for my motor and what kind of gains i could expect, if i put new heads on? I plan on driving it more than i plan on taking it to the track so i will need heads that are street heads. I am also on a limited budget.
Any and all suggestions and recomendations are appreciated. The specs I have on the motor are listed below.
The rods are 5.700 stroke (a little longer) Molly rings with forged flattop pistons, the whole bottom end was balanced.
The heads are from a 350 engine they have had a 3 angle grind job on them, and had stronger over sized valves installed with bigger springs for a higher lift cam. Up to 540 lift. Manley valves 2.02 intake valves 1.60 exhaust valves. The cc of the head i believe are 68 which would make the compression ratio 9.7:1.
Crower cam grind: 288hdp lobe center 112 intake 288 exhaust 296 duration @ .050 intake 234 exhaust 246 gross lift .497 .504 crower hyd lifters and single springs for the cam crower aluminum roller rocker arms ARP stud kits for heads and journals ARP bolt kits for everything else (intake, exhaust, carb, timing cover ect ect).
High flow oil pump with extra volume oil pan ( i think it takes 8 qts)
edelbrock timing adjustable timing chain.
edelbrock performer RPM air gap manifold
Accel HEI distributer with HEI unit
Accel 8.8mm racing wires
363.6 HP @5200
407.5 torque @4000
363.6 HP @5200
407.5 torque @4000
