HELP Roller Rockers install problems : Valve lash caps or Non self aligning ?
12K views 12 replies 4 participants last post by  Calderone
#1 · (Edited)
What a turn down ! The adventure continues !
Bought a set of Gold Crane Cams Gold Roller Rockers (Self align version)
i thought i needed the self align version since i have '87 Corvette alum heads,well today i made the time to install them and ....BOOM
Clearance problems ! Crane Cams says that the body of the rocker don't have to touch the valve retainer,i have this problem with all of the exhaust valves,but not on the intakes,so i have 2 questions here
- Should i sell this kit and buy non self align rockers ? non self align rockers has the roller tip exposed outside the body,and i think that will touch the valve tip only
OR
- Should i buy valve lash caps to add clearance ? what's the way to install them,or they go over the valve tip only ?? i don't want to take the heads off or valves off or any major dissasembling of my springs ...etc check them here
There are lot of valve lash caps ..but which valve lash caps ?????? there are lots !!!!
Here some pictures of what's going on :
Exhaust Rockers body clearly touching !!!
Zero clearance !
Intake a bit better but not perfect in my opinion :
Intake and exhaust differences :
What you think ???
HELP !!!
#2 ·
Lash cap won't work for you because it will be too big around to fit between the self-guide "ears" on the rocker. You need to get rid of those goofy factory exhaust valve "rotator-type" spring retainers and replace them with the same style retainer that is on the intake valves. The rotators have one place -- IN THE TRASHCAN!!! They have no place on any bigger than stock rebuild, don't know who set your heads up but they should have known better.
Not what you wanted to hear, but the only way you are going to make things work.
Another thing you've got wrong is you CANNOT use self-aligning rockers at the same time you are using pushrod guideplates -- one or the other, NEVER both, it will tear things up and bind things up. I would ditch the self-align rockers and the goofy rotators and get the correct retainers and rocker arms for the guideplate set-up. It's either that or keep the rockers you have, remove the guideplates and replace them with a headbolt washer under each rocker stud to equal the plates thickness. You will still need to ditch the goofy rotators!
#4 ·
You can change the rotator retainers out with the heads on the motor using the correct valvespring compresser tool. All you would have to do is swap to the same type and size retainer that is on the intake valves ( looks to be just the average SBC non-rotator type), but you will have to put a shim(or shims) under the valvespring to equal the difference in installed spring height between the two different retainers. It might be easier to just change to an aftermarket stock diameter performance spring to avoid all the shimming, but I don't know how hard it is to get the proper parts in your area.
The factory installs the rotator to supposedly equalize seat and valve wear, but they go straight into the trash at rebuild time as the amount they help is sketchy and they are heavy as far as valvetrain parts are concerned.
#6 ·
You may have trouble with coilbind or too much spring pressure using the ZZ4 spring with the rotators as they are spec'ed to be used with standard retainers. I could be wrong as I don't know the specifics of the ZZ4 spring, but if it is better than a ordinary lo-perf stock spring you will want to check for correct installed height and coilbind
#12 ·
Here`s a way you can change the valve springs without worry of a valve falling. Remove the spark plug, cycle the engine where the piston is half way down in the bore on the compression stroke, feed the cylinder with small diameter rope through the spark plug hole, when you have plenty of rope in the cylinder cycle the piston up, when it stops then you can remove the valve spring. When finished changing the retainer move the engine backward to lower the piston back down and remove the rope.
