Hello new here, I own a 4 wheel drive shop in Florida and specialize in Jeep conversions to chevy engines.Some are stock others more performance. Now onto the problems I seem to keep having cooling problems with these conversions. They get up to around 220 degrees and can climb higher but I shut them down or bring them back to idle and they will cool down.
The engines seem to be overheating in higher RPM ranges sitting or driving and pulling like up mountian roads , all idle very cool, all have the same radiators aluminum from a place called Novak, and Flex a lite 3000cfm electric fans, and all are Automatic TH400. one is a 350 with iron chevy heads and I don't know what kind of cam but sure does run great. the other is a built 383 with E-Tec Edelbrock 200 heads a lunati Voodo cam and a Proform electric water pump, neather of these can run at standing still at 2000RPM or driving down road with out running hot takes a little while depending on outside temp 30 to 45 mins. Both have Edlelebrock carbs 650CFMs. All is new in both just can't figure it out. So I am looking for help. Have played around with differant Thermostats higher flows, stock ,160 to 185, timing, and distributor curves. have not checked spark plugs for richness, but both have had Holleys on them also and did the same thing. Any input would be great.Thanks
