I would like to calculate (very roughly!) how much RPM I would need to start spinning tires in a RWD or AWD car.
Assume the following: the car is stationary, in 1st gear, the tires are cold, neither flat or overpressurised ie "normal", and assume I have enough torque. Neither suspension, nor mixture of the tires nor their profiles should be taken into consideration.
Is it possible to roughly calculate the RPM needed to spin car tires with just the following info? (and if not enough torque is available how much torque would be necessary to lose traction)
Wheight: 1665 kg
Tirewidth back (for RWD): 295 mm
Tiresection (I hope it is the correct translation into english): 30 mm
Tirediameter: 20"
max Power kW: 405
max Power kW @ RPM: 6500
max Torque: 680 Nm
max Torque @ RPM: 2500
How would the same formula look like for AWD?
Thanks in advance!
Wheight: 1665 kg
Tirediameter: 20"
max Power kW: 405
max Torque: 680 Nm
Thanks in advance!
