How much does it cost to have a set of heads ported and polished?
100K views 10 replies 10 participants last post by  NAIRB
How much does it cost to have a set of heads ported and polished?And what does this procedure actually accomplish.How much horsepower gains are we talking about?Is the cost worth the gains?I have dart iron eagle 180/64cc for my 350.Thanks bm
#4 ·
do it yourself:
buy some junk (cracked, from a Honduh, etc) heads and practice.
take your tool and do it yourself; mostly clean up the extra material and smooth out the contours. Be conservative.
Pay for it: have someone that knows his stuff do it for ya.
Here is a company that I have heard alot of good things about. Scroll down to see prices on porting. As far as how much hp, it depends alot on the size of your cam now,and the other engine components. If you have a fairly small cam now, and you go with a full competition port and job, and a new larger cam to take advantage of the better flow, on a street motor like yours, I dont think 50 hp would be out of the picture.
http://www.revolutionaryperformance.com/products.htm
Adam
IMO, I dont think you'll see large gains worth the money to pay someone. Most dart's i've seen were cast pretty good and just a little cleanup was all that was needed, no major porting.
I would however recommend doing it yourself but like the other's said, practice on a junk head first. Take your time and be careful and you'll be alright.
#8 ·
$400 for a port job with no chamber work. $600 with smoothed and polished chambers and you pay the machinists bill if any other work is needed. That's the life-long buddy price. It's $1000 for everybody else
Unless you've already exhausted all other avenues and absolutely need the last horsepower you can wring out of your engine, porting really isn't worth the expense unless you do it yourself.
Larry
#9 ·
Porting properly done can be one of the most cost effective methods of improving HP. A cylinder head that flows well will make power. Why do you think the LS1/2/7 engines make 400+ HP on the dyno stock? The heads flow.
Johnsongrass has the range but to narrow it down if you want to get things flowing decent it's going to cost you around $500 to $800 for that type of head. An AFR type head I've invested up to $1500. An All Pro or Brodix raised runner/15 degree/18 degree LOTS and LOTS. $2500 is not a bad place to start.
Is it worth it, it really can be. What you want is the porter to tell you what they expect the head to flow from .200 through max lift before and after porting. You want improvement througout the lift curve. Darts can be improved. Can you do it yourself. Sure. Will it be better? I doubt it.
What we like to do is flow the head first, compare to spec type heads of similar design and say this is where we think it can get to. After porting, the head is reflowed and results shown to the customer. Again, expect to pay around $500 to 800 for that type of head.
On a set of AFR 195's (which are an OK head) we have dynoed 60+ hp increase after porting. Back to back, same motor, same dyno. Thats with about $800 into the heads. AFR's are far from optimum out of the factory.
