Crazy Fast on Ice said:
I was curious if anyone had a good setup idea/info on a 350 to achieve a higher HP rating, but keeping the Torque as low as possible. This may sound like nonsense
but for my application on racing on ice with stud less tires it is exactly what I need Thank you for any input
HP and Torque are mathematically linked by the equation; HP = TQ x RPM/5250. So, for a given engine, if you move the tq down the RPM curve, high end HP will drop and the opposite is true if you move the TQ curve up.
There are some things you can do to improve the overall torque, which not only benefits the low end, but if you can broaden that torque curve, you can extend the HP range a bit. Common ways to do that (depending on the engine configuration)
1) raise compression. On a dyno chart, raising the compression will take both the TQ and HP curves straight up.
2) increase head port flow without adding appreciable volume. Bowl blending/pocket porting is a common practice which (if done right) can increase flow more than you increase volume. High flow makes high HP. High velocity makes good low end torque. On a dyno chart this usually leaves the low end alone, but stretches both curves out to the right above 5250 RPMs
3) higher ratio rocker arms (provided you aren't lifting too high). On a dyno chart, this tends to lift both curves straight up by the ends leaving the middle alone.
4) forced induction/nitrous. On a dyno chart, this looks better than porn
5) wider LSA cam. On a dyno chart, this typically has the effect of broadening the curves; typically takes the right and left ends up, but the peaks in the middle come down.
The other idea (if done right) is adding cam duration in conjunction with proper head flow increases and compression ratio increases. This will raise the RPM at which the engine peaks its numbers, but raising the point at which the engine's torque peaks is not always a bad thing, either. Take a look at the picture below and you'll see that while the second engine in the graph has a higher torque peak RPM, it is still making almost as much torque down below, but the total average torque under the curve is vastly increased. Plus look at how much extra peak AND average HP you get up top. With a TH400 and 3.73s you could stand to take your torque curve up a touch and not be mismatched, but it should go along with a compression increase and improve head flow. Of course, it all has to be matched, and you have to be sure that the engine can handle the extra RPMs, but a mild increase in duration can produce better averages without killing the bottom end. The secret is choosing the RIGHT duration. The factory almost always selects a duration that is pretty small.
The other thing you really should take advantage of is head technology. Today's heads eliminate some of the trade-offs. In the past you had to have either port volume OR port velocity, but more modern heads (like Vortecs) have been shown to have far superior flow without having to resort to a huge port. Combine that with the fact that the combustion chambers in modern heads take advantage of new discoveries, and its totally a win-win. For instance, let's assume you have 8.5:1 compression with 76cc heads right now. Swapping on Vortecs with 64cc would raise that to about 9.5:1. Alone that can be worth 5+ hp without affecting torque. Add in the boost in flow and you have much more potential, and the modern chambers mean you don't have to run anything more than the 87 swill you put in it now. Reduce your overall timing to more like 32* instead of the factory 36 or 38* and you are set. Some folks are claiming a 30 hp increase just from a Vortec swap.
I know I sound like a broken record these days, but this build screams for Vortec.
