im trying to find a way to how i can run my 383 stroker on pump gas. it has 12.5:1 compression so i was mixing 50/50 with pump and 100LL. that started to get old and exspensive fast so i switch over to E85 and bought a E85 carb. come to find out thats not working out to good for me either. i would like to just lower my compression so i can run on pump gas and have 400whp. this is what my car has
port matched and angle milled bow tie heas with stainless manley valves 2.065 int 1.625 ex 58cc combustion chambers
flat top pistons
victor jr intake matched to heads
3/8 chromemoly pushrods screw in studs plates and roller tip rocker arms
292H comp cam with rhodes lifters
850 holly double pumper with rear power valve
msd 6a electronic timing control
i know i want to get some aluminum heads for it. would that and some larger cc work with pump gas? or would i have to change to some inv pistons? also before i switched carbs to e85 it ran a best of 13.1 at 108 at the track on street tires. help please!!!!!!
flat top pistons
