Well I got new engine installed an fired up. Ignition timing set to 10* for now. Problem is now I have a surging idle, if I set it below 850-900. The idle air screws make little difference, they do kill the engine when turned all the way in. I can turn one all the way in ,then the other all the way in and engine will die 2-3 seconds after second screw is bottomed out. Spark plugs are black, obviously very rich. So carb is getting excess fuel some where. I did notice while attempting to adjust air idle screws, that when starting 1.5 turns out, the only slight change I could find was turning them in, again indicating a rich condition. Boat has been sitting since October, when I lost the original engine. How often do these Holley carbs need to be rebuilt? I am assuming that while having this carb off and turning it over to inspect and remove gaskets while installing on new motor that either i knocked loose some debris or messed up a float setting, who knows. It will sometime idle correctly for a short time after revving the engine, and sometimes just not returning back down to idle setting for a few moments. I have not messed with auto carbs much, but it does remind me of dirty carbs in the atv days.
Surging idle could be caused by a vacuum leak, but due to the rich plug reading I am sure that would not be the case, which would surely indicate a carb issue, correct? Vacuum gauge reading is steady, other than following the surging idle. Is there a way to clean up these plugs or do I need to replace them so future readings will be possible?
