i have a set of trick flow heads that have a max lift of .540", the springs are single coil 1.470 os diam. the installed height is 1.780, i am planning on installing a solid roller cam shaft in the engine that these heads will be going on,the max lift will be .570", the springs that comps recommends for this shaft is #977-16, they have a seat pressure of 155 lbs and open pressure of 441 lbs, NOW ? the installed height of the 977-16 springs is listed at 1.850" can i run these
springs installed at 1.780 or will there be to much pressure, also there is .060 shims on the heads now, i could go with a 015" shim which will give me a 1.825" installed height, what are my options, thanks
