Installing bellhousing dowel pins (sbc)
1 reading
14K views 6 replies 5 participants last post by  v8hed
Simple question... how do you know when they're in far enough? I had a quick look down the hole before tapping them in and couldn't really see a positive stop for the pins.
Thanks.
#2 ·
There's no rule for the depth, just put them in far enough that the protruding end is enough to get a good fit the bellhousing alignment holes, leave approximately the thickness of the bellhousing exposed.
They can be had in different diameters, from .0621 to .0625 for a tight fit. Extra long are available, up to like 1.5 inches.
#4 ·
Although i've never done it,(changed the dowel pin's to longer) I've been told that the longer one's make the installation easier. ;)
what i do to make installation of a trans. easier (along this same way of thinking)
i take a couple of long bolts and cut the head off and bevel the end and then I grind a groove into the end, (for screwdriver removal)
now you have a couple of alignment pins to get the trans. started with
