if you are can you tell me your specs and what your idle speed is ?
I'm running a 350 bored over .60, with the 274h cam, an edelbrock 1405 600cfm carb, block hugger headers, performer eps manifold with an open spacer, and ported 305 heads with 2.02 1.6 valves, this setup is at like 10:1 compression give or take a wee bit
so i've got the idle speed set to 1000 rpm, I've never run an idle that high because this is my first time running such a large cam(yes i know it's still small) and i'm not too comfortable with my idle in four figures
