I have had this C5 Corvette for 17 years now. It has never had an engine problem. Now it has a problem that I am going to describe as a dead hole.
I need to diagnose this problem, but I have no experience with an LS1 engine. I have more than 50 years of experience with SBCs, carbs and distributors. Not bragging but I am pretty darn good with the old SBC. I just have absolutely no experience with computer-controlled spark or electronic fuel injection.
I changed the plugs in the LS at about 50K. It now has 83K miles on it. That is all I've ever done to it except normal maintenance.
It is not a miss as the cylinder never comes to life. It is just dead and running on 7 cylinders. It ran fine then I parked it for a couple weeks. Started it the other day and it was chugging at idle pulling out of the garage
Has to be fuel or spark.
I guess I need to find the dead cylinder first. Then determine if that cylinder has spark. Is it safe to remove a plug wire, put an extra plug in it, ground the plug and check for spark? I'd hate to fry something electrical. Or can I put a timing light on each plug wire to check spark? If no spark is it likely to be a coil? Or what else? If there is spark, which I'm betting is OK, how do I check for a plugged injector? In our 410 sprint car engines with mechanical fuel injection, we pull the injectors and clean them after every race. Can the LS injectors be pulled and cleaned?
What else do I need to look for?
Anyone have any tips or tricks to help in the diagnosis and repair?
I would appreciate any help!
