An Ohm meter is your friend. I've never found an accurate schematic concerning wire colors.
I always end up "ringing it out" with an ohm meter.
But usually the two blues are front turn signal, and the greens are rear brake/turn, I think white comes from the brake switch, and orange goes to the brake switch, then you'll have two, or three to flasher, and one hot lead, and black may be the horn.
The dash indicator is drawn from the front turn signal wires.
Like I said, an ohm meter is your friend, and can tell you what is what, especially if you have the switch out, and in your hand.
Start off by process of elimination, the horn wire will be obvious, as will the 4 turn signal wires. Then by looking at the wires and contacts, you can determine the main "hot" lead. Then all you have left is brake switch and flasher wires to get sussed. that's where the ohm meter comes in.
Just remember, the brake lights, and rear turn signals run down the same wire. The turn signal operates by breaking the circuit every second or two on the wire selected by the switch.
Between a 66 and 76 the colors are similar, not Identical, but similar. You can also use the 66 switch in the 76 column, but you won't have hazard flasher. (if the column came from a van, without ignition on the column)
I hope I've helped, and not muddled it up.
