Anybody that has recently responded to my thread about overheating with a/c on can put that on the backburner for now because now the damn car is overheating without the air on. As some of you might know from my previous threads, i had my timing chain slip off my gears because of worn and broken teeth. I put a new oil pump, water pump, pushrods and timing gears and chain. Yesterday i completely put the engine together and with extreme difficulty finally got the timing close enough for the engine to idle and rev cleanly. After running for no more than 5 minutes the temperature went up to 230 than about 10 minutes later 250. I adjusted the valves by the book with the engine off, one cylinder at a time. I took the thermostat out but that didn't help. It didn't do this before the timing chain went. I'm getting so fed up with this crap
