No it is not opinion, it is fact.
Let me try to explain in my drunken state.
HEI (High Energy Ignition) Was introducted by GM in the early-mid 70's to replace the POS low volatge points ignition, especially fo remissions reasons. Points style ignition relies on a set of "points", or called breaker points the are being constatly worn down by normal use as they open and close with every spark. Basicly they close and current goes throught the points. This system has it's problems. off the top of my head. 1. Points style systems cant operate at much more than 30,000 volts with out frying the points(typical for it to be at 20,000 volts) 2. Even at the normal voltage, points wear out with time. 3. ponits style ignition allows current to flow to more than one plug at one time at high RPMs, hense why they are NO good for anything above 4,500 RPMs(current can either flow at the points, or at the contacts of the small distributor cap of points style ignition)
HEI: Has no points to burn out, or cause arcing. HEI setups from the factory run at between 35,000-40,000 volts(hense the bigger plug gaps) and can generate a much better spark. HEI setups usually have the big bulky cap with the module on top to prevent arcing in the cap from contact-rotor-contact. HEI caps usually have an electronic spark control module, eliminating the mechanical points/cam and allowing spark to flow on a stock setup at or to near 7,000 RPMS.
Now all this is just off the top of my head in my current state, so if I got something wrong, your more than welcome to correct, or add to it.
Points(like the TH-350's!!!) are a thing of the past, they are almost totaly useless, and for todays cars they ARE totaly useless. It's liek comparing a computer composed of vacuum tubes to a computer composed of transistors, it is a thing of the past and should be buried!
