And this is the reason why I don't waste much time posting on this forum. Just because YOU don't know how to do it doesn't mean it's not possible. This forum is full of old school guys (and I'm not picking on the old guys, I'm probably 2-3x the age of some of the people here, I'm older than you are hcompton), that if it's not how they did it 20 or more years ago it's not possible and what they were doing 20 or more years ago was old school then, or at least ignoring the possibilities offered by the technology at the time
silverback im lost on how you have a 305 with lt1 heads.
Yea, I know. You're lost.
1 have a 93 vette 350 lt1 and a 77 camaro 305 and there is no possible way you can install the lt1 heads on a gen I block. They dont work...
Huh, I have a '97 WS6 TA (LT1 car), an '83 and '87 TA (305 SBC cars), an '87 Formula 350 (350 SBC), '92 K1500 (350 SBC), 2012 Taurus SHO, 71 Mach 1 (M code 4bbl ram air car), 2004 Cummins Ram... does that make me an authority on EVERYTHING to do with those drivetrains?
It sounds like a good idea but the lt1 heads are reverse flow cooling and the 305 did not come in any 305 flavors IIRC.
There is a combo of parts that can make a Gen II 305 but its a silly way to make power and im not sure it works in the real world.
So your engine cant be OEM stock it cant have lt1 heads and yes lt1 heads can flow 250 cfm but they would be hard pressed to do it on a small bore motor.
It seems like you have some info wrong in many ways. Not the least of which its being supplied water from a electric water pump to the front of the heads like the regular gen I gm heads. But the lt1 does not even have water ports there you would be pumping water into the lifter valley.
Just saying. Lots of smart people here and many of them have had there hands all over these motors many times.
Now you may have corvette 113 aluminum heads that flow in the 250 range but still not going to work on small bores and not the lt1 setup.
The engine in that picture does not have anything lt1 other than valve covers that appear to be lt1's. The rest is gen I block.
The only thing about those that isn't LT1 is the valve covers, they're some cast aluminum ones that I ground smooth and were my first attempt at powdercoating.
I have a set of '128's (early 'vette aluminum) and '113's that I've ported, but they don't have nearly the potential that the LT1's do. I don't know why I'm wasting my time but if you really recognise LT1 heads then this is a pic of the ends and you might be able to pick out the casting numbers on them, these are the heads on the stock SBC 305 bottom end:
As for the 305 the motor can be made to produce about 350 hp but its a lumpy racy sounding build that cost as much as a 350 build when you figure machine work on the heads. I have a 305 in my camaro big cam high compression full length headers good intake four barrel and all the other toys it probably make 250 hp at best and is a bit weak down low and never develops the punch up top the 350 would with the same work.
You can build a strong 305 that lands you 300+ hp its not smooth or truck worthy. But do all the same work for the same money with a 350 and your into the 400-500 hp range. You may also find the 305 never makes the low end punch the truck will like.
If this was my deal i would just run a junk yard motor over the built 305. you can buy a low mile vortec block for under a grand and have your goals met with little effort and better setup if mods are wanted later on.
Hope this helps.
No, it's a ridiculous waste of time.
I'm not suggesting anyone build what I built, but this high mile 305 bottom end will loaf along at idle (here is a video of me driving it for almost 3 minutes on a winding hilly road between 600-1100rpm):
https://youtu.be/pJy2owHq9rk
Here is it idling on a COLD morning... it's a bit rough here but nothing you couldn't deal with in a daily driver, and it averages mid 20mpg in mixed (DC Metro traffic) driving:
https://youtu.be/STbY5SeJkOk
and this is a 305 that revs and makes power past 7000rpm (and do the math what still climbing power and >100% VE means at 7000rpm, and I can provide data logs showing that 107% ve fueling in the high 6xxx rpm range is going lean, meaning that it wants more fuel there).
Now again, I'm not suggesting that they build this for their truck, but if i can build this, you can surely build a 300hp 305 that would be happy in a truck with an OD trans behind it.
