Is the power steering box from a '75 Firebird the same as a '76 LeMans??
Thanks!
Thanks!
Physically, probably- but the internal stops will likely be different, this can cause wheel scrubbing or an insanely large turning radius.opelitis5 said:Is the power steering box from a '75 Firebird the same as a '76 LeMans??
Thanks!
Actually, that would be a quick ratio.latech said:that s right they did make a close ratio box also but travel stop to stop should be the same. the close ratio gets there with less turns of the wheel.That puller in the picture is bareley a pittman arm puller.but it may work.
The steering boxes in question is hopefully the Saginaw 605 or 800 series steering box and not a 525 w/small pittman- or some other box. An 800 box has a cover w/four bolts securing it, the 605 units use a single snap ring that holds a round cover into the top of the housing.the 500" box they call ( I guess) is the same pittman shaft size as the manual box. The 700 box ( whatever) is the box with the larger pittman shaft.
Tell me about the time deal... I wonder quite often if the project I'm on will be my last...latech said:thats good info right there cobalt. Did not know exact name/number for all these boxes.Definetly can stop one from leaking but have not spent enough time studying the particualers of different boxes. Some noteworthy changes from box to box especially some of the f body ones that effect turning radius. I wish I had more time for hotroddin and had to spend less time working to live.
I sure don't, sorry.opelitis5 said:As an aside Cobalt327, do you have the definitiver part number for the 1969 H-O Qjet??
