Questions about gold leafing?
13K views 32 replies 14 participants last post by  Fryguy
Hello
I have searched the knowledge base as well as the whole Internet for some help with doing some gold leaf on a motorcycle tank I am painting. I have wanted to try this for some time now. My questions are what is the best type of sizing (adhesive) to stick the gold on with? And can I use urethane clear coat over it. I have seen some spray sizing at the local craft store but will the clear coat attack it. There is all kinds of info on the net if I was wanting to do some Marta Stuart stuff but I cant find much to do with automotive paint.
Any help would be much appreciated .
Thanks
Man you guys are awesome
I have seen the Mona Lisa brand adhesive but did not know if it would hold up under the urethane clear coat without attacking it? I just sent the piece to the sand blaster today. If it weren’t so darned cold here in the Midwest I would be ready to prime it this weekend.
Thanks for the replies keep them coming. :thumbup:
#8 ·
HK hooked me up with some copper leaf and a small bottle of adhesive (Mona Lisa) ... I'm gonna hit the hobby shop soon and look for something big enough (at least 6" square) to use as masking to cut some design ideas out of. Then I'm gonna experiment with some gilding. The copper leaf is very silver in color, with a touch of copper -- I like the color!
Alan
54 Chevy Pickup
#9 ·
Engine turned look on Silver leaf
I am also working on a paint job using Silver(aluminum) leaf on a Motorcycle fender. I have been practicing with the leaf but I want to go a little further. I want to put the engine turned swirls onto the leaf. Like Ed Roth. I know if I use the abrasive technique, like I do on stainless or aluminum stock it will shred the leaf. I did a search through the old threads but I have not seen this discussed. I heard of someone using cotton on the end of a wooden dowel but want to see if anyone knows a tried a true method. Any help would be extremely appreciated. Thanks.
Fryguy
#10 ·
I have never tried it, but a painter I knew years ago used a wooden dowel with a felt cloth rubber banned over the end- he just spun it back and forth in the fingertips on aluminum leaf, overlapping as you would in turning... again, I have never tried it but it was super cool! The felt was just those little squares from the hobby store. I have gold leafed some stuff and as stated the Mona Lisa stuff has worked.:thumbup:
#12 ·
outlaw17 said:
Is there such a thing as silver leaf ? if so how do you get it to have a prism effect like the picture below ? Check out my photo album for more samples .
i am assuming that since you are asking you didn't paint the couple bikes in the pics in your gallery. i have seen that chopper before, somewhere. i have a picture of it too. it is an interesting effect and have seen it a couple times but never found out exactly what it was. its not any kind of leaf though. its a special effects paint and its not made by any of the big manufacturers. it might be one of the products made by metalflake corp, possibly vreeble but dont quote me. if you find out let me know, i am interested.
#14 ·
I really like to see custom painting, I have done VERY little so I can only dream when I see stuff like that, thanks for the education on this tread.
Tell me, looking at that fender and tank photo it looks like a "mid coat" of something like Chromaillusion was applied over the leaf, could that be?
If not, I would think that it would provide a very cool look. :welcome:
#15 ·
Fryguy- yeah, I watched and he just rolled it back and forth with the fingertips like we used to grind the valves on the old motorcycle engines!! I watched him do 'inlays' on the sides of a rear fender. I think it was a half inch dowel with the felt just stretched over the end and banded. Saw the bike done and it looked great and as far as I know lasted good... If I remember correctly I have a pinstriping/painting book that shows it done also- if I get time I'll look for it tonight and let you know!
#17 ·
Really, some felt rubber banned onto the dowel. I mean its the same theory in effect. Something abrasive relative to the hardness of the metal.
Check your local WallyWorld or even the grocers in the aisle that sells light bulbs etc. They have packs of small felt circles for the bottoms of lamps, ashtrays, etc. that already has the sticky on th ebottom and comes in various diameters.
Kevin
#21 ·
couple things.
i have seen the engine turning done before and the guy i saw do it did use a velvet, not felt tip on the end of his dowel, he also had some padding stuffed in there to.
the other thing.... i found out about the holographic crackle finish on those parts. i was wrong, it is like a leaf effect but its not silver, its special stuff on a mylar backing thats applied just like gold leaf and it is designed to have that holographic effect. its available at coast airbrush. here is the link. you need sizing glue and a special iron for the application.
http://www.coastairbrush.com/pages/96.html
hey willys36!! found out about this from craig fraser, you might know him or know where kal koncepts is, he is from out there in bakersfield where you are.
#23 · (Edited)
#24 ·
That preturned stuff must be different from the normal leaf. The stuff I used is so thin that it didn't lay down in perfect sheets - there were wrinkles, patches etc. It looks great and seamless when done but if it had a uniform pattern to match, no dice. I can't imagine how a preturned pattern could be laid down uniformly enough to look good.
#26 · (Edited)
It only take a 1/4 to 1/2 turn to mark the gold. use the real stuff that comes in 3 inch sheets not the fake stuff in 5 inch sheet, it engine turns better.
If you use the vinyl stuff from SignGold I heard you can't clear over it. It will delaminate.
like willys36 I like the variegated gold leaf
some variegated gold leafed stripes
some variegated gold leafed flames
