Updated info
I got the new booster and master cylinder installed, and then read through the brake bleeding process for my truck. Some of this info might be useful.
- There is a release button on the proportioning valve and it has to be pushed in while bleeding the brakes (I think that deactivates the valve and you get equal pressure to both sides). My manual showed a GM tool/bracket to hold the button, but I was able to use a small clamp from HD (the type you use to hold two pieces of wood together) to hold the button down.
- The GM process is to start bleeding at the wheel closest to the master cylinder and work toward the one farthest away, since there is no sense trying to make an air bubble travel further than it needs to. This is the opposite from what I have always heard about starting at the farthest away wheel, but it makes sense.
- Bleeding went well the first time around, but my wife told me that the pedal was still dropping after I shut the bleeder. I thought she was just not used to the "feel" of the brake pedal, but when I got done I found the same problem, so I decided to bleed them again.
- I started out go through the bleed process again, but then noticed a drop of fluid around one fitting on the master cylinder. When I sat in the truck pushing the pedal down hard, and looked out under the hood I found that under high pedal pressure it was seeping around one fitting. I took it apart and cleaned the flare surfaces, and finally got it to hold.
Lesson learned: On the first round of bleeding we had one person in the cab and one under the truck, and I was checking at the calipers and drums. but nobody was looking under the hood for leaks at the master cylinder. It surprised me how much that very small seepage created an extremely low pedal.
Bruce
