According to your figures, you have 0.139" clearance between the retainer and valve seal at maximum valve lift. The accepted minimum clearance is 0.090" so your clearance is good with plenty to spare.
In 1965, I had a Chevrolet 30-30 Duntov cam in a new 1965 327 over the counter short block my 1956 Chevrolet and I was using 1957 283 Power Pack heads. That cam had .485" valve lift and there was only 0.450" clearance between the GM retainer and the valve guide boss. I had the valve guides machined .125" and machined for PC teflon positive stop seals. I was also using vintage Crane aluminum retainers which are .090" shorter than GM retainers. The Crane retainers and most other high performance aftermarket retainers are not designed to hold stock O-ring seals so they will provide a extra .090" valve guide to retainer clearance.
I was using new GM valve springs set up at 90 lb. at 1.700". That is too weak and too close to coil bind for a cam with .485" valve lift. The valve springs were good for 6,000 RPM until I finally broke a spring and the engine swallowed a valve. I was lucky, the only damage to my engine was a broken spring, bent valve and chipped cylinder wall. Even the valve guide was still good.
Strange but true, I was racing a Edsel at the time! I still beat him even after I lost a cylinder.
