Hey all,
I've been having starter problems with my car again. I have 350 chevy, stock heads, intake, 4bbl carb, comp cams camshaft. The problem that I'm having is the starter making some aweful noise. I had shimmed the starter with 4 shims on the one side so far.... (1) 1/16" shim, (2) 1/32" shims, and (1) 1/64" shim. They are all on the outboard bolt of the starter ( to bring it closer to the flywheel). I used a screwdriver to pull the pinon gear into place, and it looked like it was pretty tight to the starter, but not too tight. After i had shimmed the starter, i tried starting it again and it sounded good. I let the car run a little while, about 15 minutes while i timed it. I shut the car off and went to start it again, and the starter was making a horrible grinding sound again. My battery had been a little low before, but after i shut the car off and went to start it again, it didnt have much juice left. Could a low battery be causing the starting to grind like that? Or should it not grind even if that battery was low and it is just improper shimming? thanks for your help in advance all
