Is there any advantage to using a spring behind axel as opposed to a spring over or vice versa. I am starting to construct my own frame for a 41 Ford 1/2ton rat.
If that work's for you.. Great.. Keep up the good work..Like I said,follow Ford's design basics in the front end.
It works.That's what I do.
What was the point you were making?? No offence is intended. A squared frame? Look at your pic 5I build chassis too..:thumbup: What kind you want..
Now this will look like a quick google jobLike I said,follow Ford's design basics in the front end.
And back at you!MERRY CHRISTMASS TO ALL:thumbup:
This one has no bump steer either..What was the point you were making?? No offence is intended. A squared frame? Look at your pic 5
I have a reversed corvair steering box on my gasser just like in your pic. The difference is that I mounted the box on the frame so the pitman arm was excatly at the center position axactly right along side of the radius rod mount bolts. Then I
positioned the foreward steering link exactly as long as the rods are. No bump steer. This is Imprtant on a gasser going through the quarter as I had enough to think about, 11 seconds at 128 and shifting. Holding the steering wheel straight was a no brainer, just trust castor when pulling whelllies on a gasser.
Your right.. But planes and helicopter wasn't supposed to be able to fly. BY THE BOOK'S..Now this will look like a quick google jobbut I learned this 36 years ago at that rod shop when I was 17 and never forgot it, the Akermann angle was created (discovered?) by Ralph Akermann in the 1860s! Before there were even cars, this principle existed, pretty cool stuff.
No, actually they do exactly as they were designed to do. When man was first trying to figure it out, no they didn't fly, because they were trying to fly like a bird. But the design of the wing was done on paper long before one was made. It was proven on paper with mathmatics that the air going over the top of the wings shape would take more time thus creating lift by the air under the wing. This is a scientific principle that makes it work. Many people would have died trying to simply make things fly if this principle hadn't been created on a piece of paper with a quill pen.Your right.. But planes and helicopter wasn't supposed to be able to fly. BY THE BOOK'S..
Thank God someone didn't read them book's..![]()
You might want to do a little more reading.. They said the helicopter was not suppose to fly..No, actually they do exactly as they were designed to do. When man was first trying to figure it out, no they didn't fly, because they were trying to fly like a bird. But the design of the wing was done on paper long before one was made. It was proven on paper with mathmatics that the air going over the top of the wings shape would take more time thus creating lift by the air under the wing. This is a scientific principle that makes it work. Many people would have died trying to simply make things fly if this principle hadn't been created on a piece of paper with a quill pen.
I don't spend much time at all on forums anymore..
Now I remember why.
DeeW,my point to you was,if you're building the frame from scratch,
follow the basic 4" dropped axle spring on top,stamped crossmember,
cross steer,and you will have a solid chassis.
Also be sure to use tie rod ends on your tie rods,and not heim joints.
Forged steering arms. Don't fall for the cheap prices online,buy American and you will
only need to buy it once.
A little bend in the steering arm doesn't come anywhere close, not even in the same ball park, or city the ball park is in with what we are talking about. It's like comparing a rock chip on the hood of your paint job "ruining" it to pouring two gallons of Aircraft stripper over it. :drunk:man, most of the cars with spindles that got hit in the nose, or bumped a curb. and bent the tie rod arm on the spindle are running around with ankman totally f up
yes you should address it, if you can.. if not.. you "might" get tire wear.. my bet is the tires will dry rot before you wear them ..
One Question for the chassis engineer's here..
