getting somewhere
This car was built late 50s early 60s and the workmanship isn't exceptional. So the excessive perch angle didn't surprise me.
It has a straight tube axle located by hairpins. I know this is a :nono:, but after 40 years with no visible problem I'm not going to change it. The spring mounts on top of the axle with single stud hangers. These have to be loosened to adjust the axle caster. Caster adjustment is made via the hairpin clevises.
I plan to use 7dg as a base for the caster adjustment. Educated guessing says that it probably won't go beyond 9dg or less than 5dg to make optimum caster. Toe at 1/8th, tierod behind axle. Camber at 2dg for zero scrub.
After a couple replies to jumpstart my brain, I came up with this. Good thing I like doing fab work, both literally and figuretivly.
Logic tells me that the spring caster should be the same as axle caster or nearly so. This would put the spring on the same plane as the axle so rebound wouldn't put a side load on the hangers.
Putting a tapered shim in the hanger would probably be a problem because the shim would be a 19dg taper in the worst case scenario. This would present a tapered surface to tighten the bolts against and this would lead to loose or broken bolts.
Is there a fault in my thinking? Thanks for help.
