I should have seen that coming. I meant 12 inches under a load.
""The 2-3 piston I only removed the spring and block the feed port to it"".
If i didn't think you are referring to the accumulator piston in the valve body,
I would consider this sentence to hold major clues to your problem.
Nouns and adjectives would really help us here.
Question,
What gear are you missing?
From your first sentence, You said,
""So I rebuild my th400 bc it would only shift once. It's still.doing it.""
From what i am reading, the problem was there before you did anything to it.
So its what you "didn't do" is what we need to find out.
Question,s
Did you find burnt clutches ? and if you did, did you change the rubber seals in the drum or seals on the pistons? and if so, how did you get the pistons back in?
Did you miss the center lip seal in the direct drum, or put it on the drum upside down.?
Lots of good advice here.
Start with Ricks advice and hand pump 17 inches directly into the modulator and drive it. Make sure you recheck your fluid level before driving.
Even if it still does not shift, leave the pump on it till you figure out your vacuum issue.
