OK earlier on I asked about the makes on a timing Chain. Lining up the dots ect... I ended up taking the front timing chain cover off to make sure dot to dot was correct. It was. I was told that both dots should be at the 12:00 for the installation of the distrib. That would be TDC on the compression stroke. It was just that when I checked it. After checking all this I had done my homework correct it had seemed. I still get burping and some fire out of the carb. I've tried moving the advance around both ways and it still acts like the timing is wrong. I have never dropped a distib. in without a smooth fire up as I am very anal about double checking. That doesn't mean I didn't but everything checks out. I still have one hair left and open to anything at this point. Should I go against everything I know and put the distr. in 180 out? I am dumbfounded and listening...
Thanks Cat
Thanks Cat
