Also check ro see that the vacuum advance is working, since its primary purpose is to improve gas mileage at cruise speeds. If base timing 12 degrees BTDC, when you pull vacuum on the advance it should advance your timing about 18-20 degrees (about 30-32 total). If you don’t have a dial-back timing light to get a good measurement, at least verify that you get it to advance when vacuum is applied.
When there is no power to the electric choke it will move closed, so that when you start the truck (cold) you will have less air coming in, which gives you a richer mixture. The choke also move the linkage to a higher idle.
As the choke heats up from power being applied, it moves a curled bi-metallic strip inside and the choke gradually opens. Your original choke may have used engine heat to operate, , and the electric choke is a conversion. To simplify your operation and not require a separate switch, check for a wire to the wipers that only has power when the ignition is on, and use that for choke power.
