I have a its-a-snap wiring harnessin my '39 chevy. The harness has all connections for GM column ,and I am using a cadillac column. I have two brand new sockets, and bulbs for the rear they are GE 1154. With that said here comes the nightmare.
A month ago I was sitting up brake lights, any the one on my passanger side kept blowing after a little bit (I only went through the second bulb). Last week I plugged in the relays for the turn signals and hooked them up (with new bulbs). One brake light blew, but both turn signals worked. I tried working on them a little bit ago to see if I could figure it out. Turned the car on the flasher fuse blew (no signals or brake now). Every time I put in a new fuse and turn the signal the flasher fuse blows.
I unhooked the wires from the lights and pulled them out to check to see if they were grounding out. with no cuts in the wires and nothing at the fuse panel to be grounding out I tried them again. Fuse blows when turn signal is on.
Is this a bad turn signal cam? Where do I need to look next?
