Using Oil 383 Stroker
1 reading
7.8K views 11 replies 7 participants last post by  red65mustang
This engine is in a street rod. Here is my frustration. The engine uses a quart of oil every 400-500 miles....the compression is good....it has no oil leaks....it doesn't smoke... it runs very well...... The baffle in the valve cover has enough clearance.....Someone suggested using synthetic oil which I did around 1000 miles ago but it still uses the same amount of oil. Does anyone have any wisdom they can offer?
Thanks
Doug
#2 ·
Thanks
Doug
Excess oil consumption comes from it getting around the rings or down the guides.
While holding good compression is a good sign, oil consumption around the rings is also dependent upon the oil ring set and the second compression ring doing their job. Problems in this area will not show on a compression test and most like not on a leakdown test either. That said, a leakdown test is most valuable as it does give a pretty good indication of compression ring seal to the wall and piston. The rings not only do their work against the cylinder wall but also must perform properly within the ring groove.
The valve guides, especially the intake are sensitive to clearance and quality of the guide seal. Worn guides and or valve stems allow space for oil to be drawn into the intake. Hardened seals especially those of O ring and umbrella will allow oil to flood the stem and upper guide, the vacuum inside the port will do the rest. Unfortunately there isn't a good test short of disassembly and measurement.
#4 ·
How many miles are on the engine?
At what milage did you start using synthetic?
Did the engine reach very extreme heat levels during break in?
What type of rings are in the engine (cast iron, moly, plasma-moly,etc...?)
Who honed the engine and to what RA?
After you do the leak down and if it comes back poor, then mix some comet with gas, pour it down the carb and keep doing it until the rings seat. Or some Bonami, if you can still find it. Not a great solution but a easier one than tearing it back apart.
If you are using an aluminum intake, what gasket are you using? This is a common leak point if you are using gaskets meant for an all iron combination (such as Felpro Permatorque Blue that have a steel shim core) I have seen this too many times to count. It's a slow, steady loss that never shows any smoke because it is a tiny constant leak whenever it's running ( but will sometimes show on a longish decelleration in gear from a high rpm).
#10 · (Edited)
you have to test the pcv baffle to know your not picking up oil...
every time you let off the gas there is instant 25Hg+ and max oil pressure at the baffle to siphon oil...
drill 2 holes seperated in a plastic peanut butter jar lid (any brand is fine) so you can mount two 3/8" fittings in the lid...
so you can connect the jar and lid in series using hose with the pcv valve and carb connects....
(just for the idea a pic' attached)
many after market valve covers have the pcv directly aligned with a push rod (DUMB!) so more better baffles are needed
simple project that may well give the answer...
edit:
petg plastic peanut butter jar can take "some" heat but a glass jar is maybe better
#12 ·
CRS=forgot to say
make the fitting from the pcv valve extend further by a inch (piece of hose whatever) into the jar so that any oil picked up will be directed toward the bottem of the jar,,,,only air continues out the other fitting on to the carb....
there can be a super small intake leak due to alignments or gaskets....
do correctly re-torque all the intake bolts,,,hot and cold cycles do make parts move....
