what grit hone for a rering job with moly rings
44K views 9 replies 5 participants last post by  t-bird60
i was thinking in the niebor hood of 320-400 grit.
this is for my buddies turbocharged v6 camaro,he ended up breakng the 2nd ringland on one piston. for now he is rebuilding it as cheap as possible.
6 new speedpro pistons quick hone job to get the rings to seat not the best way to do it but it will get the car up and running for now
#6 ·
Agreed, FlexHone CAN'T remove an appreciable amount of material, nor will it change the "shape" of the hole.
It is highly recommended, unless the cylinders are rebored, to use a "power hone" or "rigid hone" for moly rings. Molys have a hard time "seating" in bores that aren't "round". ANY taper or out-of-round will inhibit that. Iron rings are recommended if not reboring.
We use a Sunnen "625" stone for most moly applications. Higher level "race" engines get 820 and a "plateau" hone. Iron rings get "525". I don't think these numbers represent the actual "grit", but those are Sunnen's numbers. NOBODY knows more about "honing" than Sunnen... :)-
Jim
#8 ·
We've successfully used plasma-moly "file-fits" when things vary ever so slightly. You can "plate-hone" it again and have a tad more piston-to-wall without really hurting anything. Set the gaps accordingly and as long as you don't get TOO crazy with clearance, it'll be fine. Adding a graphite coating to the piston can add about .0005". Even in a "budget build", wall finish and ring prep are just about the most important aspect of a "blown" application.
You didn't say which V6. 3.1? 3.4? 3.8?
Jim
#10 ·
hone
with the moly rings, you want a smooth cylinder. I use a sheet of 600 wet or dry sandpaper wrapped around the stones of the hone.(the 3-legged type). I put the oiled sandpaper in the cylinder, then put the hone inside of the paper. anything coarser will chew the moly off. Lets face it, a ring job is not a lasting solution, although I have done it many times and works fine. Check the top ring gap at the very top of it's travel in the cylinder. If too wide, it'e going to have some blow-by. I had my own engine rebuilding shop for several years. and am just sharing what I learned.:spank:
