Hello guys since the weather is finally getting better here in Ohio I am finally going to be able to start driving my truck again and work a few kinks out but anyways I am curious as what do you guys who are running 1st gen small block chevy's that are mild and daily driver type setup what do you guys get fuel mileage wise on your build?
What I mean is heads can be whatever but for camshaft size 230@ 50 duration and smaller and can be either roller or flat tappet and carb size does not matter along with compression and can even be stock. I am just trying to see how mine does compared to other builds similar like mine.
My engine is in a 1996 s10 with a 350 turbo transmission and 3.42 rear end gears. My engine specs are 350,9.1 CR, 275/280 208/221 @50 474/510 zz4 hydraulic roller.
World sportsman 2's gasket matched and bowl blended with competition valve job. Holley 600 1850 VS carburetor with edelbrock performer eps dual plane with aftermarket hei high output ignition setup.
I have not been able to really calculate my mileage yet but so far it seems maybe I am getting 13 to 14 mpg at the very most but that is probably being hope full.
My engine should be in the 350/375 hp and close to 400 pounds of torque at the flywheel. Hope you guys will contribute.
Thanks Eric
Thanks Eric
