do we use racing gas mixed with unleaded or do we use a fuel booster?
You are one brave man here... taking a stand in favor of the boogie man...E85.Thumpin455 said:I switched to E85 and started making fuel at home from cattails and grocery waste. Its as simple as a carb swap, or just pull it apart and modify it with numbered drill bits. I modify Qjets to run ethanol, they work quite well for it. It doesnt usually cost 30% drop in mileage, even though you have to increase the fuel flow about that much. Up here E85 is $3.08 as of two days ago, and we are almost always higher than most of the country. Compare $3 to race gas prices and even if it did take a 30% hit in mileage its cheaper by far.
You can run over 13:1 with E85 pretty easy. The 455 in my 70 GTO has right at 13:1 and a 700R4/3.42 12 bolt behind it. It doesnt get hot, makes a ton of power, and at oil change time the oil looks just like it did when I put it in.
Octane boosters dont work, retarding the timing and running it as cold as possible on gasoline hurts power and mileage. If you have EFI its simple, just put half a tank of E85 in it, if its carbed its easier to switch to E85 than to figure out how much ethanol is in each tank.
Go here http://e85prices.com/e85map.php and enter your town in the search bar. It will show you the stations carrying ethanol near you.
timothale said:I have seen a few double hump heads with cracks between the center two exhaust valves. be sure to have them checked for cracks. with the 2 exhaust valves that close together , the heat is concentrated there.
Have already had plenty of run ins with the naysayers, thing is most of them have no first hand experience with ethanol. I have first hand experience and have been running it for years, building carbs, engines, and not using anything exotic, just slightly modified stock stuff. Usually modified with a drill bit.Mojo56 said:You are one brave man here... taking a stand in favor of the boogie man...E85.
Be ready for the naysayers...
