swcallison said:
hello. steve here, just reading comments about reverse flow pumps.
maybe someone will enlighten me.
I'm trying to help my son on his 95 chevy 4x4. he recently purchased a 96 350 vortec from a dealer. the 95 had a serpentine system on it. will the 95 water pump work or is there something additional he needs to get it to cool properly. the only visual differances i can see between the two pumps is that the 95 has a single hose from the heater core where as the 96 so called reverse flow has the same plus another hose connection next to that one which i believe would connect to the intake. is this correct? what is all this static about reverse flow? I'm confused. If you can help, thank you!
I was confused too...however, this should help clear it up as i understand it.
Your water pump from the 95 will work fine. What confused me, is how the serpentine belt worked differently from the V-belt pully system. The serpentine causes the waterpump to run backwards, hence the term "reverse rotation" however the water flows the normal direction (from the radiator, down through the bottom of the motor first.) THe reverse flow engines, are LT and I believe LS motors, which the water actually flows the other way, through the heads first, and the bottom of the motor second. Anyway, bottom line is, your 95 pump will work fine.
Now to answer about the hoses. YOu need 2 hoses. One from the bottom of the water pump that goes to the bottom of the radiator. Then you ahve a second hose that goes from the top of the radiator to the thermostat on top of the engine. Those are the only two hoses that you need. For the heater, you have one hose that comes from the water pump (hot water) that goes to the heater core and one hose that comes from the heater core back to the pump (return hose). I hope this helps.
