I want to know what the difference in performance you would have going with a destroked 400 vs. a stroked 350 to 383?
now would the 406 be a stroked up or bored out 400? i didnt know u could stroke up a 400? I am looking to build a smallblock nat. asperated that will make 500hp and be able to rev to 8000rpm without it coming undone. which would be the best route on a 8k budget?ericnova72 said:If built to the same rpm goal with the correct parts to match each build, there won't be 10 hp difference between them. This was actually tested by one of the magazines a few years ago. 383 and 377 with the same parts.
My thoughts on destroking an engine are "Why take cubes away from an engine? Cubic inches = HP, making an engine smaller is just stoopid :drunk: .
Using modern engine components the 406 will rev just as high as the 377, and so will the 383.
I'n sure all the "revs faster" and "revs higher" fools will post up in this thread shortly.
that is very true. i like the thought of a 383. but people have told me they are truck motors not car motors. iw ould also like to run a good radical sounding cam in it. i heard that the 377 is more of a reving engine but like u said its hard on parts. would it be best to get a short block and then add my own top end or buy a turn key?ericnova72 said:406 is just a 400 bore .030" oversize with the factory stock 3.75" stroke, you could also use a 3.875" "stroker" crank to make a 421 at the .030" overbore in a 400.
Either of these, and the 383 will easily be able to make 500+ hp and you won't need to rev them over 6800 rpm to do it. If done properly 8000 rpm is 700 hp territory for any of these engines, but is unnecessarily hard on parts, and you won't likely be able to do it on an $8,000 budget. The heads alone(BIG) to make power at 8000 rpm will cost $3500 all by themselves, then you have to add the valvetrain..
What is the reason you want to rev the snot out of it? If 8000 rpm and just 500hp and budget are your goals build a little bitty Z28 302 clone with a roller cam. It still won't keep up with a 6800 rpm 383 or 406.
Rpm just for the sake of rpm, or bragging rights, isn't very smart.
pinks all out! I wish my car was ready for the one by my house this summer. I have an 85 elcamino i am gonna be putting this motor in. it sounds like the 383 is the way to go. i am looking at proformance unlimited for my builder. does their 383 mechanical roller 510 hp for 9k sound like a good way to go? it comes ready to drop in. could u check these guys out and see the build and let me know what you think? What do you think would be a good tranny rear gear set up for this? i want it to be a scary fast street car and a good performer on the strip. i really appreciate the advice. A MUSTANG KILLER! :mwink:ericnova72 said:Our 11-1 383 with Pro-Action(now RHS) Iron Lightning heads just went a new best for this engine of 10.61 @ 124 MPH at the Pinks All Out race today at US 131 Martin, Mi. 3400 lb '67 El Camino, Powerglide w/t-brake, 4200 stall. Motor is nothing real special, $3500 in parts and machining, Scat cast crank and rods, TRW forged flat tops. Spins to 7600 all the time, 7200 shift point. Been together 6 years, refreshed with new rings and bearings just once, it was last year.
We missed the cut by just .05 seconds, they took 10.3x- 10.56 second group of 32 cars. Event was a total blast. Coolest big event I've been to in a while.
Definately not a "truck motor", even though it is in a vehicle with a bed![]()
curtis73 said:cubes are cubes. For many years people thought that stroke made torque and bore made HP, but that has been proven untrue a few million times. Throw the same parts at a Buick 455 (big bore, short stroke) and an Olds 455 (small bore, long stroke) and they will make the same power. Its true that longer strokes have more leverage on the crank, but with a smaller bore pushing on it, it is a wash.
Destroking is a quest for RPMs. In racing, it sometimes makes sense. On the street, it never makes sense. The only time destroking makes sense is if you're trying to spin more RPMs than your current rotating weight can handle. From idle to 5000 rpms, it doesn't really matter what the bore/stroke ratio is for most common V8s; they'll make the same power and torque.
So, I guess the question is, what are your goals? If you're building a street engine, destroking for fewer cubes is kinda counterproductive. You can make the same HP, but with less torque and you'll have to rev it higher to get your powerband. On the street, cubes are king. Don't destroke unless you're looking for 7000+ out of an SBC
Back to the buick/olds comparison: They will make the same torque and HP on the street. If you plan on going over 5500 RPMs, the small bore of the olds becomes a limitation to valve size and therefore flow. If you're looking for additional peak HP in higher RPM ranges, choose a bore/stroke combo that puts the emphasis on larger bore. In your case, you're talking about either destroking a 4.125" bore, or stroking a 4.030" bore. Both will perform great, but why destroke? Keep the 400 cubes and take advantage of the extra displacement.
ok. yeah that seems like a good idea.r they a pretty good builder? i thought it was a little much. plus they dont dyno the engines so you dont know if they are a true 500hp motor as they say. thanks for your help eric.ericnova72 said:$9000 spent and it only makes 510 hp??? WTH?? You should be easily able to make thar much power for less than half that much money. $9000 should result in a 700+ hp giant killer of a smallblock. Buying a complete motor from a crate is not really the most cost effective way to do it. Maybe look at Scott Shafiroff Racing engines. My cousin bought a Shafiroff 582 BBC (makes 968hp) for just a little over $11,000 dyno'ed and delivered, for his mud racer.
I should clarify -- When I say you could do it for half that much, I mean you will have to build it yourself. Still, only 510 hp for $9000 isn't much of a deal. Shafiroff has a good reputation, builds Pro Stock engines for some of the NHRA/IHRA teams, and there are other good choices out there, shop around/search.ericnova72 said:$9000 spent and it only makes 510 hp??? WTH?? You should be easily able to make thar much power for less than half that much money. $9000 should result in a 700+ hp giant killer of a smallblock. Buying a complete motor from a crate is not really the most cost effective way to do it. Maybe look at Scott Shafiroff Racing engines. My cousin bought a Shafiroff 582 BBC (makes 968hp) for just a little over $11,000 dyno'ed and delivered, for his mud racer.
Oiling Issues- just what do you think the oiling issues are.ap72 said:If you are running it on the street I suggest running a 5.7" rod- actaully a good stock rod with ARP bolts will be a great match. You get better rod angualarity and a lighter piston for very minimal cash- a good set of remaned rod will be about $125- the same as remanning your 400 rods. If you keep it under 6500 RPM and no detonation the rods will live fine- higher than that and you're probably going to blow the stock block.
Best bet for a cheap low trouble street combo- 400 with 5.7 rod. A 6" rod will lead to oiling issues- best left to the track.
Appreciate your opinion/choice, I just have never experienced the oil problem- guess my #2 ring was always doing its job. I do believe that using 6" rod in a pure street application is a waste of time and money.ap72 said:It is not as big of a deal now, but to some people burning 1-2 quarts of oil between changes it is still a big deal- I think it is, while many people think its fine. But when you expect to burn a quart of oil on a brand new engine between changes to me it sends up a red flag. In drag applications it may not be as big of a deal, and many people live with it in stroked ut LS engines, but I like my oil below the oil ring, not on top.
I know many will argue this and really I guess its a personal choice- I like the pin below the ring.
I am now eye balling shafiroff's 427 sbc with the hhr kit.making 560hp for 8k. plus the quality of parts are top notch. what do you think about a 427 sbc? hydraulic or mechanical?? i thank you for all your input.ericnova72 said:I should clarify -- When I say you could do it for half that much, I mean you will have to build it yourself. Still, only 510 hp for $9000 isn't much of a deal. Shafiroff has a good reputation, builds Pro Stock engines for some of the NHRA/IHRA teams, and there are other good choices out there, shop around/search.
While the 377 can shine in circle track, it does not make the most sense for street, street/strip, or all out drag race. You are going to have to turn the 377 up over 8000rpm to really make it shine, and a 7500 rpm street or drag 406 bottom end is not that expensive. I've built both, I once bought into the "high rpm 377" hype, it wouldn't run with a less expensive 406, even though it was strong. This was drag and street use, I've never done the circle track thing, too rich for my blood.65smallblock said:There is nothing "stoopid" about building a 377. for starters you can build one out of left over parts from a stroker build. Second, a 377 has less reciprocating mass/lower piston speeds and therefore it can obtain a bit more r's on a smaller budget. That is not opinionated hype, it is physics, you start revving a 400 up to 7000 plus rpms and youd better have some cash into that bottom end.
Then there is bore to stroke ratio, if you are building a rock crawler then by all means use as much stroke as possible. A circle track engine is a whole different story. Nothing "stoopid" about it, just a matter of what you want to acomplish..
You are right that typicaly you will get more bang for your buck with more cubes, but horsepower is horsepower. There is a guy who has been racing a DZ 302 Z-28 on the drag strip (not circle track) since the late 60's and still does very well in the pure stock class. (Trying to remember his name) He held NHRA track records for I think it was two years. The basic trick is he uses a four speed and very low gears in the pumpkin, just runs in a higher range where the power for that motor lives. Again, not hype, just physics.ericnova72 said:While the 377 can shine in circle track, it does not make the most sense for street, street/strip, or all out drag race. You are going to have to turn the 377 up over 8000rpm to really make it shine, and a 7500 rpm street or drag 406 bottom end is not that expensive. I've built both, I once bought into the "high rpm 377" hype, it wouldn't run with a less expensive 406, even though it was strong. This was drag and street use, I've never done the circle track thing, too rich for my blood.
The fact that you bring a factory Stocker DZ 302 into the discussion tells me where your learning curve is. Put my $4500, Pump Gas, Solid Roller, 7400 rpm 406 in the same Camaro with gears friendly to the 406, and I'll smoke him heads up.65smallblock said:You are right that typicaly you will get more bang for your buck with more cubes, but horsepower is horsepower. There is a guy who has been racing a DZ 302 Z-28 on the drag strip (not circle track) since the late 60's and still does very well in the pure stock class. (Trying to remember his name) He held NHRA track records for I think it was two years. The basic trick is he uses a four speed and very low gears in the pumpkin, just runs in a higher range where the power for that motor lives. Again, not hype, just physics.
Strokers and 400's are more versatile and extremly effective for most applications, that it true. Still, a lot of guys are building up 350's for the street and I garantee a 377 will pull more torque than a 350, but you dont hear a lot of folks bagging on 350 users as being weak for the street/strip. Hype indeed.
There may not be a replacement for displacement, but a sound plan will always trump a bigger hammer.![]()
