Whats Wrong With Grease Guns ???
12K views 26 replies 18 participants last post by  Guy Hiltz
I bought the very best hand held grease gun that NAPA offers,buy good quality grease,but I seem to always have some kind of problem with it.I actually went through 3 guns at NAPA with their manager even getting his hands dirty before we found one that worked.It seems like most of the time I end up throwing the grease cartridge away even when it still has grease in it because nothing will come out,then other times you have to pump like crazy before any grease does come out.Am I doing something wrong ?? It drives me CRAZY,please help....
#4 ·
re: Whats Wrong With Grease Guns
The biggest problem usually turns out to be air in the grease. Just a little bubble in the tube getting up unto the pump cylinder screws them up. Try taking the tip off the gun and pumping it a few times to try clearing it.
Maybe I've just been lucky, but I've never had any of these problems. I have a variety of grease guns, US and foreign made, pump and air-powered, and all work fine with no issues. There really isn't a lot of technology to it.
#6 · (Edited)
You have a trapped air bubble. remove the cartridge. take some grease from your Wheel bearing tub and pack some down into the pump head. If your grease gun doesn't have an air purge on top. little button you push down while pushing the rod back in. Then screw the cartridge housing on till hand tight then back off about 1-1/2 turns.Then push the rod back in. This will help release any trapped air.Then tighten the housing. Once you get the gun working. let gravity help you. Hang the gun so that it is pump end down. They can be a pain in the buttocks. But the method I gave above has worked well for me. Brian
I take and pull the plunger fully back like I was going to load a new cartridge. Then let it go, it tends to push the air out.
BTW, what brand is your grease gun? I have a 20+ year old PLEWS that works just like the 5 year old one I have.
#9 ·
Guy Hiltz said:
I never expected this many replies,thanks for the suggestions.I'll try and get any air bubbles out and hang it upside down next time.As for brand,its the UAP/NAPA brand.
I have had a lot of bad luck with new grease guns and have gone to buying them at yard sales from people who have had them 20 or so years and the other junk I had is obsolete. Ed ke6bnl
#10 · (Edited)
Guess working greaseguns is like opinions and them round things. What I do is pull the plunger back, insert new tube, screw cap on one thread, release plunger, wait a minute then tighten, swear for a minute or two then it pumps fine. This way works without the swearing too, but isn't near as much fun. :)
It also helps if you take the little metal tab out of the end of the tube :D .
#12 ·
OH NO! I find that if you don't swear a few times and threaten to throw it in the garbage it won't start pumping :D .Brian
#13 ·
Doc here, :pimp:
I've never, Ever, had a problem with grease guns..in all my years.. :D
And the remedy is soooo simple.. :confused:
Simply pay the guy at jiffy Boob $20 Fazools to do it for you... :thumbup:
By the time you blow up 2 or 3 "Well Engineered" grease guns,...
4 or 5 tubes of gloppy~Arsed grease dripping all down your sleeve and shirt, filling your breast pocket..(making your non~Filter camels smoke like they need a ring job..)
Snapping off a few Zerk Fittings, trying to "Hold the day~um gun" , Pump the Day~um thing..and hold the Day~um Greasy hose tightly on the Day~um zerk fitting..(The instructions NEVER told you: You are Required to grow a third Arm/hand For this operation) ...
Reinventing the wheel to try and get the now busted Zerk fittings Out of what was previously a well greased pivot point..
Finding out that Grease Really Smokes a long time on hot headers..and seems to live forever under intense heat..and smells like a BBQ at a wrecking yard..
Using 196 Red shop rags for 12 zerk fittings..that seem to leak like a sieve..
Finding that a greased Drive belt is NOT necessarily a good thing for continuous operation..
Two hours in the shower...
One point Five hours Cleaning the ring out of the tub, and sink bowl..
two hours washing the towels and wash cloths (along with your shirt..Two More bottles of shout..)
Four hours in the Laundromat..
Two bottles of shout applied to the shirt..
One New pack of Camels...
30 minutes of cleaning it off your shoe sole..(after you tracked it across the white carpet to the bathroom and kitchen to get another brewski..)
2 Bottles of Resolve Carpet cleaner..
Rental of Steam cleaner Before the main squeeze gets home...(and REALLY gives you a grease job..)
Watching Fido, cover his ears and eyes with his paws, in total disdain, knowing full well, If you don't clean this disaster up before the Female of the Species returns home..you'll be sharing the "Bunk house tonight" in the backyard together again..
Watching the Young Tech at Jiffy Boob inflict all this self abuse upon himself for $8 Fazools an hour..PRICELESS!!! :thumbup: :D :cool:
That $20 Fazools don't look so awfully bad now...
Doc :pimp:
#14 ·
Hey Doc,that just cracked me up !!!!
I might just print that off and frame it... LOL
But I bet if the grease gun was powered be electricity you could take your DVOM and find a way to fix it..
Thanks for a laugh to start my day with.
#16 ·
GOOD ONE DOC!!!!!!!!!!!LMAO-ROF. Thats why I just take my wifes van to work when I want to grease it. I have the overhead reel I use on our fleet of 72 trucks,it's got a drum pump, so you can make a real frigg'in mess :thumbup: but at least it isn't on the carpet!!! :nono: Brian
#17 ·
We don´t even get greaseguns here that use cartridges :nono: I have to reload mine from a five liter can. :pain:
Once I´m done loading the critter, greasing the car is a breeze. :D
Tend to get a lot of greasegun farts :thumbup:
#18 ·
Grease guns , what a topic. Here is my two cents worth!
I am a lube technician by trade , in simpler terms an oiler on heavy equipment at a large rock quarry. I fuel and lube all the equipment everyday. I do have a preference in both hand held manual grease guns and air powered grease guns. I like Lincoln (not Lincoln Electric as in welding) they don't last me forever but the way I use them they seem to work best and longer than other brands iv'e tried.
Also a pistol grip style hand gun for 2 hand operation , thats all I use in a manual gun.
Follow the directions on the grease tube and the side of the gun tube as to which way the piston lip goes for bulk or cartage grease.
Keep it Lubed , Gene :thumbup:
#19 · (Edited)
[QUOTE=
Actually, I've never had a problem with my Lincoln electric gun. If you put a long whip hose on the gun, you can lay it on the ground and pump it. Negates the need for a third hand or you can just pull the switch with the electric. With a needle on the Lincoln, it will squirt grease 50 feet. Convenient for greasing things you can't reach like blackbirds. :D
#21 ·
I've said my share of swears to a greasegun as well. Used to grease helicopters- Needed three hands to use the dang gun, and at least one to hold on to the side of the helicopter so you don't fall off... Had to be creative sometimes to get to where you could pump it- just to end up with an air bubble :D
Never had the cartridges- always had a 5 gallon bucket or 1 quart cans to fill it with. It was always funny when someone would bump the rod out of the locked position while filling, and send a couple pounds of grease flying :p
Nooj
#22 ·
I have to agree with 57halfton. I also had my best luck with Lincoln grease guns. I operate a backhoe and use a grease gun everyday. If every fitting is having a hard time taking the grease try replacing the tip with one made my Lincoln 9 times out of 10 it will work better.
#23 ·
T-bucket23 said:
I have my original Craftsman gun I bought in 1973 and it still works mint. It has never given me a moments grief. The new ones are crap.
x2... mine is an ancient estate sale find, only the rubber plunger is swollen and a b* to get in when changing tubes.
#24 ·
I never expected this many replies to this post.It was kind of funny at the time,I had bought a grease gun on sale at UAP/NAPA in the town of Berwick NS,but never used it for over a year because I was driving a feed truck and had acess to an air powered greaser and use of the garage whenever I wanted it.Then when the feed mill shut down I went to use my brand new grease gun,well there was no way it would work.I took it to the UAP/NAPA guys in New Minas NS and the new manager there used to be the manager in Berwick,so they exchanged it even without a receipt,because he knew me.That one wouldnt work either,so I took it back,they took it apart and looked it all over,took another one apart,switched parts around,still wouldnt work.By this time,even the manager,Blaine,had grease up to his elbows,finally he said the heck with it and gave me the best one they had in the store,and although it works,sometimes,it still isnt what I would call perfect.
