i have a 350 bored 60 over with vortec heads i was wondering wich would be a better cam. The motor is in a 10982 gmc swb truck. also i have a 3,000 stall converter. do the these cams have a good lope to them
Cam Style Hydraulic flat tappet
Basic Operating RPM Range 2,000-5,800
Intake Duration at 050 inch Lift 214
Exhaust Duration at 050 inch Lift 214
Duration at 050 inch Lift 214 int./214 exh.
Advertised Intake Duration 264
Advertised Exhaust Duration 264
Advertised Duration 264 int./264 exh.
Intake Valve Lift with Factory Rocker Arm Ratio 0.450 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.450 in.
Valve Lift with Factory Rocker Arm Ratio 0.450 int./0.450 exh. lift
Lobe Separation (degrees) 108
Intake Valve Lash 0.000 in.
Exhaust Valve Lash 0.000 in.
Grind Number 264 Mega
Computer-Controlled Compatible No
or
ISKY - Grind No./Type 278-MEGA HYDRAULIC.450 lift rule class; banked 1/4-3/8 mile tracks.RPM-Range 2000-6400Valve Lift - INT .450 EXT .450Valve Lash Hot - INT .000 EXT .000ADV Duration - INT
or
