Can I wire 2 relays in series to a 12volt ignition wire??
What exactly are you trying to accomplish. If you mean run two relays off the same switch this is very easy. I dont know why you would actually want two in series. A little more info pleasesexypizzaman said:Can I wire 2 relays in series to a 12volt ignition wire??
That is Rude!!! What do you think the other members who read this are going to think of you now?Holder350 said:I just realized who this was asking the question.
If you don't ask questions you don't learn, and like he posted #5 03-06-2008, 07:13 PMHolder350 said:I'm not trying to be mean but I'v been in a bad mood as of late.....all I was referring to was some of his past posts.....
http://www.hotrodders.com/forum/alternator-not-lining-up-pics-134849.html
http://www.hotrodders.com/forum/alternator-bracket-mounting-sbc-help-134688.html
and this one for sure
http://www.hotrodders.com/forum/pulleys-dont-line-up-sbc-pics-help-133664.html
What kind of vehicle uses a 100 amp alt shutdown relay? This kind of relay would half to have at least 6 gauge wires in and out of it. Auto shutdown relays on the other hand, use smaller gauge wires and shut down the fuel pump, ignition, and fuel injectors. Never ever are they rated at 100 amp.Holder350 said:thanks for that oldred.....I actualy needed this a few weeks ago and had to go with a expensive 100 amp unit for a alt shutdown relay....but about 4 little 30 amps would have worked just as well.....
*kicks self in but* :smash: :smash:
There is no way you could use, or wire, 4 small relays to replace something like that. And you have the audacity to "knock down" sexxypizzaman's post's. :spank:Holder350 said:was not on a vehicle.....was on a loader.
the alt was causing feedback into the system and with the wiring cobbled up as it was. I simply installed a shutdown relay for the alt.....
not the one I used but similar.....works the opposite of the relay on the fender.
http://www.streetsideauto.com/produ...Alternator Shut Down Relay&partnumber=50105&Skip=True&LookupType=NON&Reset=True
