Hello. Hopefully you hot rod experts can help me out. This is my first time at starting a thread, so if I do something wrong please yell at me...
Here's where I'm at:
1964 Thunderbird, 390 4 barrel. I got it running pretty good about a month ago after sitting since 95. It ran real rich and smoked quite a bit at idle, but was smooth. The idle mixture screws on the carb were stuck, so I just bought a new Holley. It ran great after that, drove around the block a few times and then parked it. Couple days later I go to pull it out of the garage to wash it and it runs really rough, and was loading up really bad. Couldn't stay running in gear. After chasing around numerous possibilities it just keeps getting worse and now it won't start. It cranks ok, but doesn't even cough or backfire or anything. Here's what I have replaced so far in no particular order:
Spark plugs, points, condenser, rotor, coil, plug wires, fuel pump, gas tank, gas lines, Holley 650 w/ vac. secondaries
Last time I worked on it the timing light read right on 6* BTDC on the pulley. Compression test yielded all cylinders 140-150 psi. I am 100% sure the plug wires are on correctly. I have fuel pressure and the accel pump squirts fuel when I work the throttle. I removed the distributor and the gear on the bottom looks good. Before you say it, before I removed the distributor I put the crank on TDC with the rotor pointing at #1, and I reinstalled it back in the same position it came from, so it should still be on #1 compression.
I'm at a loss at what to do now. Thanks in advance for replies.
