Stalls when engine is hot, cold or both?
Did you have the distributor out and then put it back in, if so please describe how you maintained alignment. Roughly when installed the rotor should point to the number one terminal which should be aimed at the number one cylinder. At the same time the vacuum advance can if so equipped should point at the number 6 cylinder. The distributor being installed off a gear tooth will make the damper timing mark appear if you assume the configuration as described above. The Chevy distributor always rotates as it disengages the cam’s driving gear which also rotates the oil pump drive shaft so the distributor upon installation never engages the gear and pump drive correctly. One of the easiest way around this is to mark alignments on the distributor and intake with the rotor and cap positioned at number one fitting. At reinstall align all of these positions and set the distributor in, it will be sitting slightly proud (above) the intake. Now rotate the crankshaft in the clockwise direction by wrench, when the distributor drops on its intake seat the engine is timed, button it up.
Finding true TDC is not “essentially” doing the process, it is doing the process. A lot of degrees pass with nearly invisible motion to the piston as the crank swings over the top or through the bottom of its travels. The process of positively stopping in one direction and marling that then reversing rotation and marking that stop then marking the half way point is true TDC. Any other process leaves space for error.
Yes GM used different tab and damper combinations, most part sellers are clueless to this. We now have two generations or more of parts clerks that have no knowledge of parts beyond the computer data base if that is incomplete they have no knowledge beyond that. Consider that computer data bases inherently no nothing they are only as good as the initial information put into them by a person usually someone young, inexperienced and paid minimum wage. Combine that with it’s been a generation and some years since a last Gen 1, SBC was bolted into a chassis by GM.
At the carb yo need to be sure the choke comes off. It sounds like something is happening as the transition to the secondaries is occurring. Check the secondary air-valve for free movement. Comment to us what it feels like in the transition to where does the engine feel like it’s going to or does backfire or does it rather shudder and fall on its face. Trying to discern if it’s it’s going lean or rich. Lean often sneezes back through the air horn, rich tends to lay down on power then may come back. Either will get better by backing out of the throttle some distance.
All of this engine sounds like it’s old and unused, this does not preserve parts especially carburetors and ignition. If the carb had been run then left to dry out it is dirty and gummy inside. Electrical components are made of dissimilar elements they corrode and rot especially in damp environments.
Yes the AFB Performer and its cousin the AVS Thunder don’t like being heated, thus the need for an insulator between them and the intake, they dont deal with fuel pressures beyond 6 psi at all but unless your using a high pressure racing style mechanical or an electric fuel pump this should see pressures high enough to warrant a regulator.
