Hi,
I figured I'd start a new thread since I'm starting over with my carb tuning.
I've got a Holley SA 670 on my 355 SBC with LT4 hot-cam and Sportsman II heads.
I adjusted my idle screws and got 15 inches of vacuum at 750 RPM. The primaries were just a tad over showing a square transfer slot. But I think it was still in the range of acceptability.
I took it for a cruise and did tests where I slowly increased the RPM up to 2000 RPM. I found that if I held the RPM right at 1700 in 1st gear I'd get a bit of a lurching forward. Very light, but I could feel it. I could also hear an occasional "pop" or "puuf" from the exhaust. So I believe what I'm experiencing is the "lean surging" that I've read about.
If I'm lean when in transition, there are two things I can do... First is increase the idle jet (idle feed restriction). Second is decrease the air bleed. I decided to stick a 0.035 welding wire into the idle air bleeds to see what it would do. I measured the original hole size of the air bleed and it was around 0.078. I did some math and the welding wire would take it down to around 0.065 or so.
As expected, partially blocking the air bleed made it richer at idle. I was able to turn the idle screws in by 1/2 a turn and still maintain the same idle speed and vacuum. However, on my test drive I still felt the same sort of light surging at around 1700 RPM. I was hoping the richer transition circuit would cure the surging.
So that was a fun afternoon of playing around. I think my next move is to invest in the LM-2 AFR gauge. I think having some real numbers to check against my "seat of the pants" measurements will be helpful.
