turbo 350 and turbo 350c
17K views 6 replies 5 participants last post by  fast68
hey guys
i have a turbo 350 and a turbo 350c transmission. right now i have swapped the TH350 into the truck and am thinking the 350c is the tranny i should work on. ive read with a manual controll of the locking feature the tranny performs quite well....i know there are quite a few shift kits, transpacs, from various companies, TCI, TransGO, and B&M. any advice on what direction to go would be great. this is my everyday driving truck so i dont want to make it uncomfortable to drive but im not necessarily "easy" on the truck ether and would like it to have the performance attitude.... The amount of work is not really an issue as i have the TH350 in and working fine so i can spend as much time as needed working on it. money is a bit of a concern as i am 19 and cash isn't something i really have allot of.... but am will to spend what would be needed to make it fun and last.
its going to be hooked up to a mild 350 with estimated 300- 350 HP
thanks
Riley
#2 ·
#4 ·
You shouldn't have any problems finding rebuild kits for either Trans. The TH350C's seem to last longer than the regular TH350 trans. Maybe because of the Lockup TC/TorqueConverter allowing the trans to run cooler. The 350C's lockup TC will give you slightly better MPG also as it lowers cruise RPM 150 to 200rpms. While the trans is out you should replace every seal you can get to if it's in good shape. If it's questionable rebuild it. TH350/350C are one of the easiest to build.
Here's a few sites for Trans parts>>>>>>>>>
http://www.makcotransmissionparts.com/350-350C.html
http://www.transmissionpartsusa.com/350_transmission_parts_s/598.htm
http://www.transpartsonline.com/tpfile/tpcat.asp?TransPartsOnline=350&TransPartsType=350
https://www.wittrans.com/Default.aspx?
This tool will be needed>> http://www.transmissionpartsusa.com/TH350_700R4_transmission_tool_p/300-000jt0151.htm
Todd
the main differences in rebuild kits for the t-350c trans from a regular t-350 is the valve body gaskets.
Most sealing ring kits had all rings needed.
the variances in the bushings used at the meeting of the input shaft and output shaft is easy to take care of. I use the plastic insert style bushing at this location.
The hard parts failure spot on the t-350c was the internal spring hub for the lock up clutch of the converter. Next problem area was the solenoid.
A t-350c can be run with out the converter clutch engaged , I never seen a over heat problem with a t-350c if the converter clutch was not used.
I have never seen a t-350c last as long as a non lock up t-350 if maintenance was equal. the converter would fail first in the t-350c
:cool:
#6 ·
I'm thinking the longevity that you may have seen, SS64, may due to the "C" tranny being used behind some of the weakest SBC's and 90 degree V6's out there.
I have an un-rebuilt original w/about 100K miles on it (only had fluid and filter maintenance since new) in my '80 Malibu.
It will leak fluid if the car's not driven- usually after about a month or more of sitting- requiring a couple quarts to top it up before being driven. Oddly, I've never actually seen where the fluid is leaking from.
Lock-up and all other functions still work fine.
I might have put a Trans-Go kit in it years ago when I first did the filter the first time or two, but I'm not positive about that. But it has been a model of reliability, for whatever reason- but only dealing w/a 115 HP engine plus good maintenance- it SHOULD have lasted!
im runnin my 91 700r4 without the lockup plugged in
and have had many the same way
and never a failure or any issues
mines unplugged now because the lockup started failin and lockin and unlocking over and over down the highway
so..
never any overheating or foamin of fluid or anything
no difference in driving
same way with th350c if clutch was not plugged in
i have a th350c from an 81 c-10 pickup sitting here i need a gas converter for it so i can use it in something, it was behind a diesel oldsmobile 350 so it has 10 bolt universal bellhousing as did most or all of the th350c trannies
